Easy Store Cart Style - Question | JoomShaper
JC
John Clapps
EasyStore 3 weeks ago
I am using EasyStore, SP Pagebuilder with Helix Ultimate in Joomla 5.1.
How do I style and cnage the look of the cart. The URL shows up as my-cart at the end but there is no page with that name. Where do I find it?
Also, in a shopping page of many items, is the only way to change the oeder they appear in the grid to change their ID numbers in the database?
John
Toufiq
Toufiq
Senior Staff 3 weeks ago #155218
Thank you for reaching out, and I apologize for any inconvenience caused by this oversight. Can you share a screenshot that you want to change exactly?
Toufiq
Toufiq
Senior Staff 2 weeks ago #155320
Please check the screenshot.
https://prnt.sc/wKmZkPp7rMBf
JC
John Clapps
2 weeks ago #155350
Toufiq
Thank you for your response but this did not change the situation. The cart and payment page are the same.
Also, the second question, is there a way to change the oder of items in a shopping grid other than changing the ID of every product?
Thank you
John
Toufiq
Toufiq
Senior Staff 2 weeks ago #155411
Will you please provide me the Joomla administrator access to check the issue? And share a screenshot that you want to do exactly. Thanks
JC
John Clapps
2 weeks ago #155489
Toufiq
Toufiq
Senior Staff 2 weeks ago #155516
Please check now. I have added some css code inside the custom.css file. If you need change the padding then you can change it from the custom.css file.
templates/shaper_helixultimate/css/custom.css
JC
John Clapps
2 weeks ago #155651
Excellentthank you. I see it.
Question: Why would you not put it in the Custom CSS section of HelixUltimate? (I'm not a programmer)
JC
John Clapps
2 weeks ago #155657
One last style question. In the product grid I cannot figure out how the plug-in decides the order. My client wants a specific order to show up. How do I create an order?
https://concrete.brand24llc.com/images/2024/List.jpg
Thanks for all your help.
Toufiq
Toufiq
Senior Staff 2 weeks ago #155690
Are you talking about the sorting of product listing? Thanks
JC
John Clapps
2 weeks ago #155774
YesThe sorting of the product on the front end. It looks like it is in Alphabetical order. Is there a way to change that?
Toufiq
Toufiq
Senior Staff 1 week ago #155865
Right now this features is available.
https://prnt.sc/RLmHvTKH25tX
JC
John Clapps
1 week ago #155893
I have tried that - it doesn't help.
Right now the products grid shows up in a completely random order. Not by ID (I replaced many products to get change the IDs) or even alphabetical order of the title. I have been trying a work around for days.
If you can tell me how EasyStore comes upwith the order, it would help.
JC
John Clapps
1 week ago #155937
I found a work around by adding a duplicate list. Now each list has subcategories.The filter still works well as if it is one list.
But I need some CSS that will not show the "no results found" icon and text.
The user is still valid if you want to look at the site.
https://concrete.brand24llc.com/images/2024/Screenshot%202024-05-05%20at%202.26.04%20PM.png
https://concrete.brand24llc.com/images/2024/Screenshot%202024-05-05%20at%202.28.10%20PM.png
Toufiq
Toufiq
Senior Staff 1 week ago #155982
It's difficult if you hide the search result message. Cause, if you click on another filter where you need the search info. So, it's not possible to use css code to achieve this function by this way. Thanks
